So after having built several class 3 rigs; a Wraith, a EB tuber, a fast back Wraith, and a Ultra4 IFS I've decided to build a chassis from scratch... I like my fast back Wraith but I'm tired of breaking the plastic tube frame!
Here is the gear that is going on it.
He's the look I'm sorta going for...
For ease of reference, here are the modded FlySky version 0.6.1 firmware recipes I am using for 4WS, 2-speed and winch.
FlySky Manuals
https://drive.google.com/file/d/0B1zg08q_w1Mwd3hyRGFCZzJQUlU/edit?usp=sharing
https://drive.google.com/file/d/0B1zg08q_w1MwQklrcTlEUkxDbUk/edit?usp=sharing
FlySky Programming Guides
https://drive.google.com/file/d/0B1zg08q_w1MwWS1IVnRYRElZUTQ/edit?usp=sharing
FlySky Programming Recipes
https://drive.google.com/file/d/0B1zg08q_w1MwMVB3UkZpS0hnZUk/edit?usp=sharing
- Wraith kit
- Axial Comp Shocks (AXI30224) using the smallest rod end.
- Running 30wt oil, medium pistons.
- Springs: RR - black, RF - purple, LR - purple, RF - orange. The front's are stiffer than the rear because I'm a servo mounted winch and MG200's front bumper, both increase the front end weight over the stock plastic bumper.
- Front Axle
- Axial Heavy Duty Bevel Gear Set - 36T/14T (AX30401)
- VP steering draglink
- VP chubs
- VP knuckles
- STRC diff mounts
- Gunner pins for the CVD and for the hexes
- Dinky Wraith Link (F) (http://new.dinkyrc.com/index.php?pa...ategory_id=10&option=com_virtuemart&Itemid=63)
- Springs
- Left - purple
- Right - orange
- Rear Axle
- Axial Heavy Duty Bevel Gear Set 43T/13T (#AX30402)
- VP Rear Lock Outs
- Gunner pins for the hexes
- STRC diff mounts
- Dinky Wraith Link (R) (http://new.dinkyrc.com/index.php?pa...ategory_id=10&option=com_virtuemart&Itemid=63)
- Springs
- Left - purple
- Right - red
- Chassis
- Custom! Whatever I want it to be!
- CMS
- Front
- Rear
- Drivetrain
- MIP Driveshafts
- Transmission
- Robinson Racing gears (never leave home without them)
- Wheels/Tires
- Custom made GripFab wheels!
- RC4WD Interco IROK 2.2 Super Swamper; 3 oz front, 1.5oz rear.
- Electronics
- Savox SV-1270TG Digital "Monster Torque" Titanium Gear Servo (High Voltage) x2
- Castle Creations Mamba Max Pro (waterproofed)
- Tekin Pro4 3300kv
- FlySky 6 channel receiver
- HeyOk relay winch controller
- Servo winch
- RIGID INDUSTRIES 3" LED light bar Silver (http://www.vanquishproducts.com/riin3ledliba1.html)
- 4 front, 2 red rear (w/brake) and 2 amber rear 5mm led lights and control kit from rclightkits.com
- Various Elite, Sky and TrueRC battery backs
- Accessories
- Hobby Gear 1/10 Scale Bungee Cords (15108)
- Homemade 12" tow-rope
- R2J pull pall
- MegaFattie sand ladders
- RC4WD King Kong d-rings
- RC4WD shackles
- RC4WD snatch blocks
- Tamiya Driver #58242
- Activate 4WS mix
- EPA {long press}
- 4 {press}
- 3 {press}
- 0 {press}
- CR0 {press}
- Map the 4WS mix to ST trim buttons
- REV {long press}
- 1 {press}
- 4WS {press}
- BNL {press}
- 100 {press}
- RE0 {press}
- OR0 {press}
- Map CH 3 button to turn 4WS crab on/off
- REV {long press}
- C {press}
- 4WS {press}
- MO0 {press}
- RE0 {press}
- PV0 {press}
- OFF {press}
- Map D/R switch to control winch (channel 5)
- REV {long press}
- d {press}
- CH5 {press}
- BMO {press}
- RE0 {press}
- PV0 {press}
- Map back to control 2-speed (channel 6)
- REV {long press}
- b {press}
- CH6 {press}
- MO0 {press}
- RE0 {press}
- PV0 {press}
- OFF {press}
- * Adjust the endpoints for CH6 as necessary
FlySky Manuals
