best thing to happen for the scx chassis in awhile...
installed sets on my G6 honcho and G6 jk.
a noticeable difference in the front not lifting as easy going uphill.
"thumbsup"
Recieved mine today. Envelope had tares in it as described. But both inside. Installed now. Gained 2° from stock. Awesome!
Got mine few days ago, got it installed on mattzilla chassis and will be testing tomorow.....will post pics tomorow.
hevent recieved mine yet, and i think i was one the first mailing for the revised steel versions.
i work with alot of direct mail, and i know the mail-sort systems in the post office are brutal on launching things that are loose inside a standard envelope.
Got my steel ones thank you! The envelope was roped a little so you may want to tape the edges.
Sent from my iPhone using Tapatalk 2
When I dropped these off, the guy at the post office said he was putting them in the non-machinable bin, but apparently that's not what happened. I'm going back to padded envelopes. Shipping cost is more, but less than replacing "lost in mails".
All paid and replacement orders have shipped today, so keep an eye out in the mail in the next few days.
What postage did you buy? That's all that matters, not what bin PO dude said he was going to use.
Plain old stamps. After some more research, he was supposed to charge an additional amount for a "rigid item" or non-machinable surcharge.
Now, all packages are shipped First Class mail, with tracking numbers.
Do yourself a favor, buy a scale and print you postage from home. It's cheaper than the PO, no handwriting labels, and you aren't counting on PO guy to get it right.
I installed the V2's since the V3's would require drilling a hole in the frame and making a spacer between the frame and the riser and I'm just not that into it at the moment.
Looks like I'll be mounting up the V3's. The V2's didn't survive crawler course practice.
Answered.
The V3's go on without too much trouble. I bolted them up on the outside to use as a template to mark the spot for the extra mounting hole then drilled it. Add two more M3X15 machine screws and 2 more nylocks to the hardware list if you go with the V3's. I thought they would need a spacer in between the riser and the channel of the chassis but turned out that was not necessary.
Introducing...
CX10 Rear upper link mount risers
These parts will allow you to raise up the chassis side rear upper link mounting points to give you better anti-squat characteristics (see below for a tech answer on why this is good...)
- Weighs only 14 grams (0.5 oz) for the pair!
- Improves performance on uphill climbs
- Works with stock SCX10 Chassis and skid, with minimal modifications necessary (just need to drill a hole on each side of chassis)
- Raises your mount up 15mm and back about 3mm, so it should be compatible with almost any existing setup. No need to change out your links!
- Increases pinion angle using stock links
- Steel V3 can be welded to chassis rails
The only other modifications I recommend would be to drill the skid mounting hole where the upper link attaches to 1/8" or 3mm so that you can screw through the chassis as well as the riser.
Here's some more info on why this is a good thing for your rig:
With the raised COG and often vertical climbs these rigs encounter, the stock squat set-up actually makes it easier for the front suspension to unload and allow the vehicle to flip over backward. By simply changing the mounting point, this turns the geometry to an anti-squat set-up and when under power, the rotation of the axle actually raises the back end of the vehicle, providing a forward bias, helping you get up and over that steep climb.
Squat vs. Anti-squat:
More info in many threads on RCC, but here's one recent one or two that I liked:
http://www.rccrawler.com/forum/general-scale-talk/453080-3-4-link-dummies.html
http://www.rccrawler.com/forum/1-9-...ughings-class2-ultra4-jeep-4.html#post4396724
Answered.
