You will program the radio for what you want it to do. If you want 6 channel, you program the radio with 6 channel firmware and need a 6 channel RX.
After flashing, it's setup for 2 channel by default. After that, you program the functions you want and what buttons are assigned to them.
Hey guys I'm sure its in this thread somewhere but if you could help me out a bit it would be awesome. I am using the D/R switch for a 2-speed TWH trans on my bouncer. I have it working on the D/R switch but I cant seem to get rid of the "neutral". What setting do I use to make it a 2 position? Flip it back and the servo goes to one epa, flip of forward and it goes to the other.
Thanks
What is the easiest way to set up my hacked GT3C to run a 3Racing winch using their factory controller? Thanks
hi there every one...so newbie and thanx Losikid... im hacked my GT3C...
but the problem is i cannot bind with FS-R6B Rx...try all the technic found here...hope some one can tell me what to do.
Thank you ik632 for that information, I thouth that is had the 3 channel as default, yesterday I just program it with 6 channel since I have a 6 channel receiver.
In that case to activate the 3ch the one on below, do I have to activate as MOM to be as it was before the hack?
you have to turn the tx off then hold bind while turning it on.Still cannot bind..!!! Argh!!!
1. Plug bind cable
2. Plug esc to channel 2
3. On car/esc - rx start blinking
4. Push n hold bind button then on radio-
Still blinking ...nothing happen
Not likely. Try putting tx in bind before the rx. turn on rx after tx in bind mode.Do that also...still no bound...or is there possiblility the rx not able to bind due to low tx batt...batt pack?
