josh6575
You squat. That is why you'll like it.
"You know you are doing something right if you have haters".
J
That just goes to prove my status as "Epic" :lmao:
Do you have to run a long drag link with the short servo arm?
Good question, I'm not sure I didn't try it, may put a funky bind in things.
LOL
I guess I will try the short servo arm with the short drag link and let you know "thumbsup"
Hope it does
as I really don't want to change the battery location to put the long drag link on.
I get a chuckle out of the fact that its 2014 and everyone is talking about the ratio between the steering arms and the servo horn like its something new. Didn't we all learn that you want to use the shortest horn possible (that still provides max throw) years ago?
No one said its something new. Until the Bully 2's I never had anything that would turn full lock with a 1/2" servo horn.
I'm just surprised that its getting this much attention. I thought that we all ran the shortest horn possible so that we could max out the servo throw and not waste mechanical advantage.
Out of curiosity what is the distance from the kingpin to the rod end hole on a bully 2 knuckle?
We are not all as smart as you.
.594"
I would like to see some better upper link mounts pop up.
Something that attaches to the top and uses cf spacers to adjust elevation so it is easier to adjust. Also a pass through hole for the rod ends so it is easier to mount.
