Next on the agenda, one of the most hotly debated parts on any rig and always seems to be the Fuse in the system.....driveshafts!!
Introducing(released already under SCX kits) the Wildboar HD driveshafts. It's no secret we here at CFM are Maxx shaft fan boys. We use them on nearly every custom build and have huge success with them as far as durability. In the plastic driveshaft market, they are King.........stop the press......Were King!!
We intentionally decided to stress test these two shafts head to head.
We decided an asphalt surface, R35 tires, and 3s lipo was necessary to provide a high power, high traction stress test. We also put a tune in the ESC making sure there was zero lunch control and no power restrictions. We installed the Maxx Shaft first. Not even half a pack in and we broke a yoke. Installed another Maxx Shaft(completely new, not just replacing the broke part) and within about the same time we had twisted a male spline half and egged one of the yokes to the point it would not stay together.
At this point I'm worried that we're gonna have problems.
We installed the RTR Wildboar HD driveshaft and proceeded under the exact same circumstances. We made it through nearly 3 full 5000mah packs before we had failure.
We ended up splitting the joint at the yoke in one end. No signs of stress anywhere else on the shaft.
Spare parts are included with the truck.
Now this was a severe stress test and unless you're running on parking lots, I believe these driveshafts are gonna shine.....and we've got a simple fix that will prevent this type of failure from happening either way....more on that later.
