Wheely king crawler chassis-lower link mounts
DiKey
Greece
Hello,
Is there any crawler chassis for wheely king axles from vendors or something to buy??
Also,are there better choices for lower link mounts?Now I have crawler king version and they have a lot of slop.What do you guys suggest?
Here is some old cad fileshttp://offroader5.freeservers.com/templates.html
And an ancient thread.http://www.rccrawler.com/forum/hpi-wheely-king/103271-scale-chassis-template-wk.html
Thanks for your reply.In thread you show me has a chassis from neweramodels,use stock transmission (a little high COG ) but looks good.However as you said,thread is old and neweramodels don't have it.
I have never used CAD and really will be difficult for a newbie.
I like the style of this chassis-build..
http://www.rccrawler.com/forum/hpi-wheely-king/207068-1st-attempt-scratch-built-rig.html
Best suggestion I can make for you is to hand draw something you like for the chassis, mock it up in cardboard, then cut it out in the material of your choice, I like poly cutting board from Walmart. I have done several chassis this way, it takes practice to get a perfect chassis but its fun.
This is a good idea but I am not so good to handmade constructions,for that reason I search something ready for wk!:shock:
if you still have the plastic balls in the rod ends swap them out with some steel ones and that should take care of the slop.
I already run aluminum links with steel rod balls.I think the problem is the plastic lower link mounts.
DNA made a cool WK chassis, But I'm not sure where if at all you can find only anymore.
I have been using the HR ones with success.. dont forget the locktite..
I want a mount with more holes like this.I don't know if I'll have the same problem with these.
I have seen two kind of chassis.
DNA RC Wheely King Chassis Kit , DNA200
SK Motion: DNA R/C Wheely King Pro Comp Chassis
The second is what I looking for but I don't know where can I buy one.
