Just make up 2 links, same eye to eye length as stock ones for now to hold you off. Tough luck though! We have a rule around here. Don't run Rc's in the street. Curbs cause big time damage!After nearly two months from initially placing my pre-order, my Yeti finally arrived today at work. I had a quick play around and in under 60 seconds, I clipped a chair leg and it broke the rear trailing arm at the eye! So fragile! Do you know if any other parts can replace it? It would have to be off the shelf direct swap as I live in Australia! Can't wait that long for the Vanquish aluminium ones which aren't even available yet! I don't know if anyone in Australia would already be stocking Yeti spares!
FYI: In Stock TowerHobbies.com | Search Results
Links would be great except he still needs something to mount the bottom of the rear shock to.
Links would be great except he still needs something to mount the bottom of the rear shock to. If you have some fab skills, you can make links and then braze or weld some tabs on them for the shock mount. BMRC has their trailing arms out already so you can order a set of them. I have a set on order while I am still waiting for my Yeti to come in the mail.
Let me rephrase that. We don't run in a office environment. Desk and chair legs break chit. Different atmosphere, same results. Need wide open spaces and places to play around. :lmao:I wasn't on the street. I was INDOORS! I clipped a darn CHAIR of all things.
Here's a couple of images of where it broke:
I wasn't on the street. I was INDOORS! I clipped a darn CHAIR of all things. and that's all it took to break in roughly 45 seconds of use.
I ordered the part from Tower last night already, but I have to wait around two weeks for delivery since I'm in Australia and I basically have no other choice but play the waiting game.
What I wanted to know was there anyone else who had managed to break it and if there were any compatible parts out there that existed from other vehicles that would fit, but after a couple of hours of searching, I guess not!
What I am going to do is chop off the broken eye, then drill a hole in the new end and attach a tie-rod end with a double sided threaded stud thingy (not sure what theyre called) or turnbuckle.
Shame you havent noticed links im making for the yeti, being local too would of saved you too
Cheers
Dan
What are these? Link?
Are these screwed intot the stock lower arms? Or are they complete replacements?
Hey anyone know the part numbers for MIP rear driveshaft setup?? I did read it somewhere but cant find it again![]()
