Messing with Sasquatch: CFM's Yeti
Alright. My 2500kv arrived today, and i have 11, 14, 15 and stock 16T pinions on the table. I guess i could try stock first too, just afraid that it would be too fast. :)
I was thinking about dual rear shocks, let us know when you can run it!
I can tell now just cycling it on the table that the shocks won't be working near as hard. Also, the bump stops contact at the same time meaning less abuse per shock and the upper shock mount now has the load spread between the two as well.
I like the fact that I don't lose any down travel from my previous setup also.
Should be cooler running and longer life for sure. Hope to have it back out next week. Waiting on a few more upgrade parts to come in and gonna finally swap out the stock servo.
Very nice "thumbsup"
Well the Yeti is fixing to get legit I hope. This has to be the coolest offering from an oem I've seen to date.
Finally a sound module with the proper tones and from a supplier that you'll know will make it durable for any situation.
So amped!!!!
From my Traxxas rep,
"Yes, there is a toggle so you can rev the engine, and it is controlled by the TX. The system is OnLy available in the slash. It's so loud is shakes the body... It's BAD TO THE bONE!!! Sooooooo LOUD!!"
Mine are a little bent but not too bad that it's hindering suspension cycle. Saw one snap in half on a really bad impact last week racing. It's gonna require buying a new tub but they are cheap also.
I'm very curious about the Traxxas OBA system as well. If the speaker sounds halfway decent it could just put a big old smile on my face!
