DickyT
I have had this chassis, transmission, and motor sitting around for a few years now. I have wanted to do an SCX frame on AR60's ever since I saw Bender's Wroncho. Also Wraith based rigs on 2.2's seem to be the go to for guys around here. I don't want to be the hold up on the trail, so if you can't beat 'em, join 'em.
To not insult to the Wroncho guys I will call this rig the WranglAR, since it's just another Jeep Rubi build.
The starting point:
So I put together a little RPP order to get this project rolling.
The WranglAR parts list:
SCX Frame
Robinson Geared Transmission
Brood 30T HHK-GR in Epic oval brush can
Castle BEC
Holmes Hobbies BRXL
Hitec 7950
Axial HD gears OD\UD
Hand Bros. CMS
RC4WD Front Bumper (this may change)
RC4WD Rear Bumper (this may change)
Axial AR60 Axle Housings
Beef Tubes - both axles
MIP Spline Set Center CVD Kit
STRC Aluminum Internal Diff Holders
STRC Front Shock Towers
STRC Rear Shock Towers
STRC Truss - Front
DLUX Truss - Rear
Fast Eddy Axial SCX-10 Bearing Kit
Axial Icon 61-90mm Aluminum Shocks
Axial Scale Rock Rails
Axial Jeep® Wrangler Unlimited Rubicon Body
Knight Custom Jeep Grill
Knight Custom Fender Wells - Front
Knight Custom Fender Wells - Rear
HeyOK 4A Relay Winch Controller
KMS Winches K3 Servo Winch
SSD Scale Hawse Fairlead
VP Poison Spyder JK LED light bar mount
VP Rigid 6" LED light bar
VP Rigid 1" LED light bar Black
VP Transmission Case
VP Motor Mount\guard
VP Wraith Panhard Kit
VP Wraith Scale Knuckle
VP Wraith Scale Chubs
VP Wraith Shock Link Mounts
VP Wraith VVD V1-HD
VP Wraith Titanium Tie Rod
VP SCX10 / JK 4 Links
Locked Up FI Spools
RC4WD Poison Spyder Wraith Diff cover
Axial 2.2 Maxxis Trepadors
Gear Head RC 2.2 Trail King Wheels
Crawler Innovations 5.5 Double Deuce Foams
The starting point:
SCX Frame
Castle BEC
Holmes Hobbies BRXL
Hitec 7950
Hand Bros. CMS
STRC Truss - Front
DLUX Truss - Rear
VP Wraith VVD V1-HD
Locked Up FI Spools
