SlomoCrawlz
Re: My big fat JK build
absolutely correct. i do indeed have longer uppers. the lift kit will be used more for different shock mounting positions more then raising the truck. it will raise it maybe 5-10mm so i can get full up/down travel out of the proline shocks without rubbing the body with bigger tires.It won't, they just raise the COG. Unless you're using for shorter shocks, or using them mounted sideways for more mounting locations.
Even factory sits a tad high, and the drive line angles are steep when 100% stock, unless you've got longer upper links the lift kits will bind up the driveshafts with stock length shocks.
