idaho
So what are the advantages of trailing arms over 4 link? Any disadvantages?
well as this is actually something i have experience with since i have been working on my fc170 build trailing arms on the rear of the frame have taken away the side swoop of the suspension. if you take a stock crawler and twist it you will notice the axles will shift or swoop side to side as well as twist if you go with a two link trailing arm set up its alot more ridged and does not allow this shift or swoop however it could cause binding if you dont have the right drive shaft and axle angles as in mine i have a 1 inch clearance gain however my axles have to have a 9 degree upright angle to them to eliminate shaft binding. but if you do your trailing arms in a lowered boomerang shape you can have a 1/2 to 3/4s of an inch flex gain the same with downward bent links without the risk of touching your drive shaft its all a case of getting the right angles and positions of everything to either maintain or gain performance. or in my case i lost a bunch of ridiculous flex that made the rig roll over quite often however i gained traction stability weight and control
I put trailing arms on my 1.9 wraith purely to have the Ultra4 look. It crawls good and does great hill climbing.
if you go with a two link trailing arm suspension bolted to the frame and have it in a boomerang shape as such here
There is not way to make a 2 link (no upper link) trailing arm system. It will always need something at top to hold the pinion angle. Double mounting a trailing arm makes it a Ladder Bar style, still needs upper links.
Everyone here is spot on, Trailing arms are just links with shocks mounted to them, not mounted to the axle. Nothing else.
To fix axle twist in a true 4 link, you need good triangulation at the chassis and axle. Also helps to have the correct geometry as well. This is true for Trailing Arms or Link systems.
