1/35 4WD FORD F-150 DIY SET (New Product Preview)
Hello,
What is the small switch on the board?
When I turn power on the ESC, I hear different tunes, but what is the difference?
I beleive it is for turning the brake function for the esc on or off
Sent from my XT530 using Tapatalk 2
Do is there an option to buy a RTR or kit truck with these axles?
Amazing little kit. Had so much fun building it.
Does anybody know if the 2s esc with the lights has a low voltage cut off in it?
Thought I should find out before I run a battery too low and burn my car to the ground:shock::ror:
I've just finished the rolling chassis, I connected up the electrics to test before installation but I have no steering. I suspect my HK-5320 servo is at fault.
I did give it a quick go (in a straight line lol) & was more than impressed at it's capabilities given the size so I'm itching to get this completed.
For the sake of £10 I may just order another servo and another ESC, don't want to order through HK twice...
Hi! Check conections first.If you post a photos on esc,reciver and servo all conected,someone can help.
To be honest, I don't doubt the way I've wired it all up (it's pretty simple) I just have no steering servo.
