Last year I bought a clone of the Redcat Sumo Micro crawler and played around a bit with it. I never got really carried away with it but it was fun.
Then I saw the new micro crawler that Hobbyking sells, the Basher RockSta 1/24 Mini Rock Crawler. 4WS and MOA axles... for $66 I couldn't resist ordering one.
I choose delivery by DHL and I got it a little while ago :mrgreen:
The steering is nothing to be proud of, but with 4WS it is livable and nothing worse than the Sumo.
The main part of the chassis is occupied of the battery box with build in ESC and RX. I plan to exchange the stock electronics for 2 esc and a RX to really take advantage of the MOA axles.
I got one of these cheep esc with break ($10 Banggood) and I have ordered another one. I hope it will arrive soon.
The battery is placed in the battery box from the bottom of the chassis. The hatch is removed but taking away the 4 small clips. There is a rubber sealing between the box and the lib giving some protecting from water and dust.
The axles looks rather good and are more compact than I had thought. I will take the axle a part later on to see how they look inside.
There seem to be possible to change the caster, like the Axial XR10/Wraith.
The hex is 7 mm like the Sumo. However, the axel stub is 3 mm instead of 2.5 mm on the Sumo "thumbsup"
The hex also have two slots for the pin.
Unfortunately, the upper links are 3-links not 4-links
Something to fix later on...
The shocks are a bit odd, atleast to me. It is more or less just a rod that goes through a spacer that is fasten to the chassis.
The TX is a standard cheap plastic one. However it is lighter and feels better in my hands than the Sumo one. It also has a short antenna which is nice. There is however two bad things about this TX... no adjustment of the rear steering. My rear tires are a bit off center at neutral... But the main annoying thing is that the button to control the 4WS mode is a small press button under the plastic lid! So stupid. On the Sumo TX the mode button is placed nicely at the thumb... Perhaps I will modify it and move the button so I can reach it easier.
Here is some comparison pictures to my Sumo. The Sumo got some Miclaws on it with some DravTech Micro wheels that makes it a wider than stock.
Here is the RockSta with the DravTech Micro wheels and Miclaws. Looks much better than stock 8)
After driving around with the RockSta on my couch I really like it. It behaves more like a bigger crawler than the Sumo does and the MOA axles opens up some much bigger possibilities.
The issues I have noticed (in stock form) are:
- The front or rear motor easily stalls if it is in a bind and the other motor is free.
- It flexes to much.
- It needs weight in the front.
- Rear servo are not centered.
- The tires are to small and to wide for my taste.
