powder4breakfast
My rear axles have a lot of play side to side.
I am running:
- Axial stock AR60 plastic axle
- Axial stock rear axle shafts
- Vanquish 12mm hex with Axial 2x11mm pins
- Vanqush Lock-outs from Stage one kit
- Beef Tubes (Brass)
Look how far the shaft can move in:
The lock-out is being held where it would sit and the pin holes would be inside if they did not hit the outer ridge.
This has caused a groove in the lock-out where it rubs when moved in:
I have replaced the bearings with new. Then I tried shims on the shaft in between the outer shaft lip and outer bearing. This pushed the outer bearing out and kept the wheel from moving farther out; but, this did not fix the wheel and shaft from moving in causing further rubbing on the lock-out.
I imagine I could put like 10 - 16 shims in between the two bearings. This would put all the shims right inside of the lock-out. This would keep the shaft pulled out and inhibit inward movement that is causing the rubbing and grooving. I do feel that this is a band-aid.
The only idea that I can come up with is that when grinding down the inner lip (see right lip on this picture) that is closest to the diff/pumkin, as per instructions from Beef Tube, that the shaft now slides too far into the center... perhaps the lip previously inhibited that..? I do not know how all this RC axle stuff works... sorry:
That being said, I used a spinning method that wore down the lip evenly around the entire circumference. I only took just enough off for the shaft to slide in to the Beef Tube and not more. If this is the cause, then every other person with Beef Tubes would have the same issue as me. I could not have left more lip and slid the shaft in to the tube.
Here is a picture of the ground lip:
I have used the search function as well as google for this issue on Bombers and Yetis. I did not find any conclusive information. Can someone offer assistance that may explain both the cause and fix for what I am dealing with? Thank you for any help.
I am running:
