I have wanted a Bomber since they were first released, but, unlike my yeti, i have patiently waited for the kit to come out. Well it arrived earlier this week, and with a nice pile of parts to go on, i am really excited to start this new project.
Axial Racing
AX90053 RR10 Bomber Rock Crawler Kit
AX31183 Hi/Lo Transmission Components Parts Tree
AX31104 Machined Slipper Plate (2)
AX31161 Steel 32P Spur Gear (64)
AX24260 AE-3 Vanguard Brushless ESC
AX31047 Brushless 3150KV Electric Motor
AXI80103 Axial Racing Rear Light Bezel & Radiator Set
AX31431 Aluminum shock spring retainer blue (x2)
Vanquish Products
VPS07940 AR60 Currie F9 Front Axle (Black)
VPS07950 AR60 Currie F9 Rear Axle (Black)
VPS07013 Wraith Scale C-Hub Set (2) (Black)
VPS07003 Wraith Scale Steering Knuckle Set (2) (Black)
VPS07510 Brass Steering Knuckle Bushing (4)
VPS07970 AR60 Axle Servo Mount (Black)
VPS07082 x2 Aluminum 12mm Clamping Wheel Hex (2) (Black)
VPS01043 x2 2.2 SLW Hex Hub Set (2) (475)
VPS07350 Yeti Trailing Arm (2) (Black)
VPS07990 Yeti Motor Cam (Black)
VPS07991 Yeti Motor Plate (Black)
VPS06933 x2 Wraith Aluminum Servo Clamp Set (Black)
VPS07036 x3 KMC Rockstars 2.2" Beadlock Wheels (2) (Blue)
IRC00060 Incision RR10 Bomber 1/4 Stainless Steel Link Set (8)
IRC00001 x2 Incision Spool/Locker
VPS07690 CURRIE ANTIROCK YETI SWAY BAR BLACK ANODIZED
Other parts
BLS1511S Goteck Servo – 2 speed
SSD00041 SSD RC Yeti 2-Speed Transmission Conversion Kit
RRP8712 Robinson Racing Extra Hard Steel .8 Mod Pinion 5mm Bore (12T)
FUTL7604 Futaba R204GF-E High Voltage 2.4GHz S-FHSS 4-Ch Micro Rx
CSE010-0004-00 Castle Creations 10 Amp Adjustable BEC
CWR-1003 CI "Double Deuce 5.5" 2.2 Crawler Foam (2) (Standard/Firm)
PTK-7800 ProTek 4mm Aluminum Long Clamp Lock Servo Horn (Blue)(25T)
TRA2362 Traxxas Shock Rebuild Kit
HH-230100003 Holmes Hobbies TrailMaster HV500 High Torque Brushless Servo
HH-250100008 Holmes Hobbies RX BYPASS ADAPTER
RC4ZE0066 RC4WD 1/10 Baja Designs Squadron Pro LED Lights
DMG Bomber spare tire relocate
DMG Bomber radiator mount
4340-3S1PD x2 SMC Factory Spec 11.1V 4300mAh 40C Lipo
BPCF9SKIDS BP Custom Chassis F9 skid plates
PIT BULL GROWLER AT/Extra 2.2 R/C Scale Tires U4 Edition - ALIEN KOMPOUND (x3)
Axial Racing
Vanquish Products
Other parts
