I've had several folks ask about the home brew tubing bender. I hope a few photos are worth 1000 words!
I put this one together with $4.00 worth of parts from my favorite recycle yard.
I don't know what material the base is made from, but it is a pretty hard smooth material. I have used half inch alum plate before.
Back side view, I use these bolts to clamp the bender in my vise.
So this is how I do the mirroring, each of the marked line are a stop for a bend.
This is one of two side tubes for a Ebay Jeep cage.
The handle is a old jack handle and I put a skate board wheel bearing on to ride the tubing or rod when bending."thumbsup"
I made 3/16" and 1/4" spacers to go under the washer as a stop for the bend post. You want the washer to be tight against the tubing, this is what keeps it from collapsing at the bend. I recommend your tubing have a wall thickness of .035 or better. I have used .020 but only on larger bend radiuses.
Here is the Ebay jeep side tube again on the lay out mat.
This is a cage for the topless RC4WD Blazer I just finished up. Several mirroring bends on this one.
Hope this helps some of you out. It's just a concept, you can build it any way that works for you. Just part of the RCC concept of "passing it forward".
Questions or input is welcomed!"thumbsup"
Ernie,
