Winch leads to rx(all 3 wires)
Servo leads to bypass(signal/ground)
Bec leads to bypasd(power)
Bypass to rx(signal ground)
Esc leads to rx(all 3 wires)
Hope that helps you help me lol
So the winch draws voltage off the RX
using only the ESC's internal BEC ?
What ESC and what internal BEC voltage does that supply ?
No separate winch controller ?
or did I miss that ?
It's my guess the winch is demanding more
voltage then the RX/ESC BEC can supply.
The winch should draw voltage from the primary battery.
2s, 3s, 4s, 6s no matter.
But a winch controller or BEC in line is what would regulate the winch's voltage.
I personally would use a winch controller...
as it will likely have a higher amp load then would a BEC.
Winches commonly require a high amp load...
because of the resistance they will endure under load.
Heck I've never tried using an external BEC for the winch.
So I didn't know if that could be made to work ?
But I don't use my TX for winch operation either.
I use the Heyok Wireless winch controller. (independent of TX control)
^ Simple push of key fob button (in or out / release and it stops)
the Heyok fob clips to my GT3-C or my belt loop on my pants.
I don't seem to misplace it or lose it. So it works for me.
Leaves my TX's 3rd channel free for TX 4 wheel steering or lighting controls.
