Bart bender
Spent a lot of time on the Kyosho sight collecting part#'s from all 777's, 7.5's, and Inferno's. Most will work cause they are common between all the buggies/truggies/trucks. Pretty sure everything on this list works on a Twin.
Big thanks to ALL who have contributed!!
Be sure to check out post #11 & #35 for non-Kyosho parts that will work too!!
Post #62 has Twin trany part #'s and brake down. Post #78 contains CVD(U joint) info.
17mm adapters at the bottom of this post.
KYOSHO PARTS
Gears
Mad Force helical set #MA050(13/43)
Helical ring: 43t #IS007
and pinion: 10t #IS008
This part supersedes to IS102
Straight ring: 43t #IF106
DRIVE BEVEL GEAR(43T) #IF20
and pinion: 13t #IF21
Bevel set, spider and side gears(4 spiders) #IF102
Bevel Shaft #97001(4x27mm/6pcs)
Diff case #IF103
Complete diff w/ steel ring gear #IF343
Part Number Description Qty. in pkg.
BRG005 8 X 16 Ball Bearing - 2
BS107 Bevel Shaft - 2
IF30-1 Diff Case Packing - 1
IF39 1.6 x 14mm Shaft - 2
IF101 Differential Shaft Set - 2
IF102 Differential Bevel Set - 4 (gears and washers)
IF103 Differential Case - 1
IF106 38mm Bevel Gear 43t - 1
ORG06 O-Ring - 2
1149 F/H Tapping Screw - 4
1162 Set Screw - 1
Shocks and Springs
#BSW73 (2)(Twin/Mad Force turbo shocks)
(these are aluminum rear shocks)
I read these rear shocks are a little longer than stock with a 3.5mm shaft. Not sure the difference between the two?
Shock set (2) #IF326B
#IFW141 (2)
Springs
These go with both#IFW141/#IF326B shock
green #IFW33G
white #IFW33W
blue #IFW33BL
red #IFW33R (this is the stock Twin spring)
These are a new long spring. "For a progressive feel" Kyosho
yellow #IF336-1616 (16-1.6/L=98mm)
orange #IF336-1716 (17-1.6/L=98mm)
green(soft) #IF336GR
white(hard) #IF336W
blue(?) #IF336BL
Ball ends
6.8mm
straight(12) #1296
offset #IS053
flange ball(4)#IF313
ball(10) #W0202
Ball(10) #BS46cheaper
Pivot Ball (3) #IFW134
M3x6 tapered washer(10) #W0141Vkinda spendy$$$
7.8mm balls, same as stock shocks
#IF55
#IF56
Shafts
Short side #BS45
Long side #MA024
Drive #IF143
Hubs
Twin, Burns/Inferno #BS19
Inferno GT,777 #IF6B?
17mm adapters
IFW107B
IFW106B
IFW326BL (narrower than standard IFW107B)
IFW327BL (6mm wider than standard)
IFW328BL (9mm wider than standard0
Add what you all have found and correct from my list.
Hope this helps everyone."thumbsup"
KYOSHO PARTS
Gears
Diff case #IF103
ORG06 O-Ring - 2
1162 Set Screw - 1
Shocks and Springs
#IFW141 (2)
Springs
green #IFW33G
white #IFW33W
blue #IFW33BL
white(hard) #IF336W
blue(?) #IF336BL
Ball ends
6.8mm
straight(12) #1296
offset #IS053
ball(10) #W0202
#IF55
#IF56
Shafts
Short side #BS45
Long side #MA024
Drive #IF143
Hubs
17mm adapters
IFW107B
IFW106B
