Castle Creations BEC version 2.0
There are 2 output wires on the unit, both of them should be plugged into the receiver. This is because the power output of the BEC is higher than the rated current capability of the servo connectors. If you are near maxing out the BEC and you only have one of the wires plugged in you could cause a fire, or at least melt the plastic of the plug. If you are out of ports on your receiver it is fine to plug them in via a Y harness with your servos. In most 1/10th scale setups you will not be near the limit of the plug, and you could plug the second one into a set of LED lights or some other accessory.
Thanks for that. I just got one today and was confused why there was 2 RX wires. RX Ports are valuable on scale trucks. :ror:
Now to throw a wrench into this....I'm using a Holmes Hobbies bypass harness. I need 8.4v going to my steering servo and the MMP is providing 6.0v to the receiver for the shifting and differential micro servos (TRX4). By plugging this second 3-wire connector from the CC BEC 2.0 WP into a receiver port, is this connection introducing 8.4v into the receiver?
yes. then u power your rx with 6.0v from the esc and 8.4v from the bec.
the three wire is a second power output and to connect castle link.
Gesendet von meinem T1-A21L mit Tapatalk
Right, both output wires of the BEC are same output voltage. If you plug one into the receiver, you'd power the receiver to 8.4v. So you'd need to keep one output plugged into the HH bypass and then allow the ESC's internal BEC power the shift servos.
