Mike Flea
Coming along great! Actuator works well, have you tried adding some weight to the bed to see if it will lift it?
Much better "thumbsup"
Very nice. Could likely use different gears should more torque be needed.
Awesome work here!
It looks like the last video you posted a link to was one of your older videos, I think this was the one you meant to put up: https://www.youtube.com/watch?v=A_dwONycZ1E
Front loader and Dump look pretty good.
Lil Blast cabinets are pretty cheap if you already have a compressor (and space) or the drill with wire brush will work good too.
The Little corners it can't reach, a little piece of sandpaper will make quick work of it.
Any suggestions on the easiest way to prep these rigs for painting? I was thinking some type on media blasting but I don't have that type of equipment. To wire wheel with a cordless drill sounds like a VERY long project and it won't get into the corners well.
