I just looked at the manual posted on the first page this thread and it says EPA for 6 channels. Maybe try this cut and pasted from the manual:
pg.13
This function is used for set the maximum servo travel limiter of each channel and adjust the
maximum servo travel limiter according to the model structure.
Feature Set:
• This function can adjust the maximum servo travel limiter of 6 channels, and the desired value
can be set between between 0 and 120%.
• Under the boot menu, enter the selection menu
by pressing the scroll wheel:
a. Turn the wheel to the (EPA) menu and press
the wheel to enter the menu operation.
b. Select the channel which need to be adjusted.
c. Select the wheel (LFU or RBU) . At this point,
the percentage is 100% (the default value of
the system), and then set the required value
by rotating the wheel key.
d. After setting, press BACK button to return
to the main page and save.
Yeah, I had looked up the procedure in the manual and made several attempts to set epa on channels 5 & 6 but no dice. That is why this is disappointing. The manuals says you can, the tx menu brings it up but it doesn't appear to work.
I do have two systems now so I'm going to see if it works on the other one.
Edit: tried adjusting the epa for ch5 on my second system and got the same result. No change in endpoint regardless of the epa settings. Maybe hobby porter will respond back to my email with a miracle cure!
