scaled
Looking forward to more details about the droop suspension.
Sent from my Moto G (5) Plus using Tapatalk
When I get my new wheels and tires, should I run the foams that come with them?
Getting the 1.0" Scramblers that are 61.7 mm tall. They are the Advanced X2SS [super sticky & super soft compound]
Will be on the RC4WD "chrome stamped steel beadlocks"
Foam it is.In my experience, when you start adding weight to these guys they really need the foam. More so for preventing the tire getting folded under binding. But then again, added these wheels and tires to my GELANDE and it works OK, but I still experience the same problem because that sucker is heavy! But they do look good on it. No need to cut the foams either.
It's all personal preference really
Most of the smaller tires don't seem to need foams in most cases, the Goodyear MTRs do in some cases, the scramblers seem to need them in most cases just for sidewall support. Venting wheels definitely helps the tires conform.
As far as the freezer trick that only seems to work for me with Losi micro wheels.
It hasn't worked on Barrage/Ambush, and definitely not SCX24 wheels. Neither did heat which almost always works or tire debonder.
I'm going to revisit the heat again trying something else.
Sent from my Pixel 3 XL using Tapatalk
Oh, I thought you were discussing the freezer trick for removing stock glued tires from wheelsI didn’t necessarily mean in general spoo buddy, just for those spots where they want to get caught up in between the rocks. Foam seems to help. We all remember how they looked earlier in the thread without the foams! (scramblers)
And just to make sure we’re on the same page, the freezer trick is so they don’t want to suck in with the change of ambient temperature (lower)? (Making the whole thing ice before you actually tighten down the bolts so they are air tight)
I used a very similar color for my daughters' Deadbolt.
Get some acetone. It will dissolve cyanoacrylate.
....done with my daughters crawler! What y’all think about the swampers with the white wheels with the purple and black?"thumbsup"
X2
Looks great, but that's one of my favorite colors!![]()
