YES! Ideally we could rally JRH to make an even smaller Revolver for the 24, but hey I'll take this too
Trying to install RC4WD steel stamped wheels on my new scx24. Wheel nut is really tiny, measures 3.8mm, which just slips around on the normal 4mm T wrench. Also, the assembly screws are very close not even allowing needle nose pliers in there. Any suggestions?
Thanks, John
I worry about trashing the plastic trans. I would want something stronger before upping the motorI will be attempting this in the future with the 370 motor mount available on shapeways (Putting the 380 revolver in I mean…:twisted::twistedUpdates in the future… Already have the electronics in place for this conversion."thumbsup"
Gamy has run a 380 and a huge outrunner in a puller build on his without an issue so far. The aluminum transmission case should also help with deflection of the case and gearsI worry about trashing the plastic trans. I would want something stronger before upping the motor
Sent from my Moto G (5) Plus using Tapatalk
My suggestion is find regular nuts (not a locking nut) and use blue Loctite. The thin wall socket wrench that comes with it fits perfectly on these."thumbsup"
Even about a thread and a half extra!:lmao:
CaliCrawler - thanks for your suggestion. Will look for hardware tomorrow. I did not remember a wrench coming with the crawler. Just looked again and didn't find anything. Double checked packaging, etc. Oh, well...
Thanks, John
Thanks, John
Thanks, John
I meant the thin wall socket wrench that came with the stamped wheels… Or I could be mistaken. I know one came with the Gelande, But I could’ve sworn I got one in the package with the rims… Probably not though. I’ve been looking for it like a crazy person!:x
Here’s what I ended up getting because I needed them for other sizes than the wheels, That should work for this. They’re a super thin wall. I sent them back because the 1.5 mm was rounded out from the package!But purchased a single of the one I needed.
Wiha 26592 Nut Driver Set With Precision Handle, Metric, 7 Piece https://www.amazon.com/dp/B000T9R2MQ/ref=cm_sw_r_cp_api_i_6.nODbVFY0GAH
Glad to help buddy!
Conpleted a 200 gate comp today with the SCX24. Pretty impressive. I found the course fairly easy with my 2 1/10 scale trail rigs but had to really think about lines with the SCX24. Needed a couple micro scale assists but not as many as I thought it would need. Awesome little rigs!
Lots of upgrades installed today. Need to run it and see how it does. Not sure about the Hobyplus shocks. Not smooth.
Congrats, looks great too!
I like the 3d printed rollcage. Maybe disassemble shocks and check for sprue not trimmed from pistons, lightly sand piston edges if needed with very fine sandpaper, like 400 grit, clean, lube, reassemble.
The shocks are more a decoration than actual shocks. Pretty much the rod is the only internal. No piston which is likely the issue. Anyone have comments on the old man emu micro shocks?
