For upgrades on the Bomber 2.0?
Obvioulsy it'll need a good servo servo saver and steering links.
If I don't get the Incision links I'll grab the SSD links but need to find a set fo Front lower links as I cant seem to find SSD F Lower links (Or do you use the Rear trailing arms in front with the SSD Links?
SO beyond Links and Electonics, I presume Axle tubes?
Are the AR60s prone to snapping? So axle tubes are a needed upgrade?
I do plan on using it as a racer more than a crawler so....
what would you recommend as Must Have upgrades out of the box?
I have a VP Sway bar already.
Thinking Axle tubes.
Links
Servo Saver
Out of the gate.
Servo ASAP
anything else?
Links
Servo Saver
Out of the gate.
Servo ASAP
anything else?
