At least with buying the kit you’ll get complete axles and a good set of driveshafts. And the fun of putting the kit together if you want.
thats about all you get are drive shafts and some universal shafts every thing else will need upgrades
the axle still have sintared gears and week plastic axle housings week chubs and week knuckles so you end up upgrading axle housings the gears the hubs the knuckles anyway so really with the kit you get good driveshafts and a clunky transmission with bad gearing
the 3gear with dig is a much better transmission with better gearing and there smoother and cheaper so thats what i would go with
If you build them piece by piece you’ll have $200-$300 in axles alone, and personally I don’t see them for sale complete very often.
thats about right but you wont ever have to worry about your axles cause thats hardened steel gears metal housings and chubs and knuckles and you can substatue brass for the aluminum parts if you want to for only a few dollers more the axles are the hart of the rig
As of a month ago nobody had the good universals or front housings in stock anyway.
i havent noticed ive been pricing out my own set of capra axles my self and have been able to find all the parts in stock
Personally I would go with the 10.2, or a vs410 chassis. Lots of vp chassis floating around with people parting out Phoenix kits.
the 10ii is vary scale if your building leaf sprung rig or another scale something or another thats the way to go
the trx4 chassie dosent look as good but the geomitry of the chassie is so much better the lower skid makes for a much better center of gravity and suspention link geomitry is better
the vs410 looks alot like the trx4 chassie but its a bit smaller and a bit more scale making it a great choice for a custom build good looks and good link geomitry
since the only really usable part of the kit is some shafts and maybe some tires i dont know if the kit comes with tires or not but if it dose there most likely r35 compound and in my opinion are decent tires i dont see any reason to buy the kit
i just finnished a bit by bit parts build of a 10ii/redcat and with the cost of the parts i havent got yet its gona come in around 250 if i were to rebuy the parts i had on hand already it would be around 300 but
a 10ii rtr is almost 400 now and if i went with the stock redcat gen7 pro there what 280 now
so i build a fully upgraded 10ii with lcg chassie metal axles aluminum 3gear trans aluminum wheels brand new tires and nice interally sprung shocks metal driveshafts and stainless steel links for about 300
so if i went with ether a 10ii rtr or kit or even a redcat gen7 by the time i bought upgrade parts i would have been in the 500 range easy
basicly if your doing a custom build you save money by peicing it together with quality parts and your less likely to have down time from broken parts
