1:20 RC4WD Grand Cherokee
GreenRiver
Kentucky
Parts:
Lindberg 1:20 Jeep Grand Cherokee
RC4WD axles
Micro DT tranny and shock parts
Micro DT esc\receiver and servo
Losi 7.4v LiPO
5:1 micro gear motor from Pololu.
SDP\SI driveshafts
SoReal tires and rims
Brass stock for frame
Delrin stock for machining (Vanda-lay mill) parts I can't afford or don't exist.
I got a little bit of a head start, but from now on I'm going to try and be disciplined about taking pictures and posting regular updates.
Still more torching to do on the frame, but here it is with motor and tranny mocked up. I had to tilt the motor to make room for the servo.
The frame so far...
Here, you can see the front dampers next to stock rear micro dt shocks. I used the micro shock caps and links, the shaft is part of a ZipZaps MT rear axle and the tube is 3.5mm antennae tube. I'll break those open later and show the detail with pics.
Next up, I'll be machining front and rear axle link mounts and building the links.
sweet build so far man, i have a big box of tamiya 130 size lower turn motors if youre interested in one, also have a tamiya 130 long can mod motor and an ABC hobby 130 mod motor.. im not sure if theyre high torque or rpm, pm me an address and i will hook you up.
A little update...
I got one of the link mounts machined on my trusty Dremel Mill. I mangled the other drilling out the center 5\16" hole with my cordless drill so I'll have to redo it. The pinion angle looks funny because I mocked it upside down.:roll:
Pics:
I am planning on doing a spring and damper setup on the front so I left a little flat spot on top that lines up with the spring mount on the model body. When I find a suitable spring, I'll machine out the top of the mount to accept the spring. Know what I'm sayin'....
Like this (an unfinished Bronco):
