monkeyracer
Ok, here's a sneak peek at my new project:
Don't you hate it when people do that?
Anyways, on to some crappy real pics (Better pics to come with the actual build):
Specs:
Wheely King Axles
Axial AX10 Transmission
New Bright 1:6 Hummer H2 body/interior (Really 1:7.5)
2.2 Beadlocks - Scales up to 17" wheels
Custom Frame
Wheely King Shocks
Custom Delrin Links
Custom Skid Plate
Dimensions:
1:1:
Length - 189.8"
Width - 81.2"
Wheelbase - 122.8"
Wheels - 17"
Height - 79.2"
1:7.5:
Length - 25.25"
Width - 10.825"
Wheelbase - 16.75"
Wheels - 2.2"
Height - 12"
Most of the dimensions are scaled down pretty close to 1:7.5, alot closer to scale proportion than many 1:10 bodies I've seen.
I got this body from another member here, and it is big. The wheels and tires in the pics are borrowed from my Comp Crawler, but I'm looking to get tires that are about the same size as the rovers, but more scale looking.
I'd like to put a sub box in the trunk, I've got the perfect one already picked out:
It fits perfectly in the back area, and the speakers actually look scale. Plus it's bluetooth capable, so I can hold the iPod in my pocket and control the music remotely. It's got it's own rechargeable battery too.
It's kind of heavy though, 11oz, but the whole truck is pretty heavy as well, so hopefully it's not that big of a deal.
I want to get a worm geared robot motor to convert into a winch, using a servo as a cheap speed controller. I'll likely just make some winch rollers for the front bumper as if the 1:1 had the winch behind the bumper.
I might get two and make a rear winch as well, but I'll either need a 6ch radio, or figure out some ingenious way to wire it.
The body has spots for LEDs and I'll probably use my 3Racing LED box to power and control them, but the headlights are begging for some huge ultra-bright LEDs, so I don't know.
For paint, I will probably somewhat "Murder" it out, and just go with a satin or flat black, with the black proline wheels.
Maybe something like this:
There will be a little work on the interior, but not much. Maybe a scale figure or two, and maybe a camera mount for in-vehicle-videos. The spur and trans needed a little trimming, but it's not very visible.
I've got a lot to do, but right now it's actually a roller, and I can at least run it in between working on it.
Any suggestions? Comments?
Specs:
Wheely King Axles
Custom Frame
Wheely King Shocks
Custom Delrin Links
Custom Skid Plate
Dimensions:
1:1:
Length - 189.8"
Width - 81.2"
Wheelbase - 122.8"
Wheels - 17"
Height - 79.2"
1:7.5:
Length - 25.25"
Width - 10.825"
Wheelbase - 16.75"
Wheels - 2.2"
Height - 12"
