1.9 Maximizer Products wheels
The Bug
State Road N.C.
Does anybody out there know anything about the 1.9 beadlock wheels by Maximizer Products? Wandering how well the hold the tire with only a beadlock on the face side of the wheel.
Never had any problems durabilty wise or holding beads, but only ran with Flatirons under lower power. 35t on 3s in scx10. Also swapped the rings for axial aluminum ones. Holes were not exact, but close enough to work.
I'm looking to run these on an SCX as well, I just figured for the price they look like a decent wheel. Thanks for the info "thumbsup"
ive had a set of these, they are good trailer tires and thats about all, id look at axial 1.9 beadlocks. the maximizer rims have all phillips hardware
They have held up well on 2 and 3s on a hpi MTDT running a Velenion system
I thru mine away, they sucked wont hold a bead if they had too, then the screws strip out the first time you tighten them up, so the bead never locks and under power the tire will come off of the rim. I had two set of them that I bought and thru away cause they were garbage for me and never worked, took the same tires and foams and put them on 1.9'' Axial 8 hole bead locks over two years ago and there still on the same rims and never un-beaded once.
I have not used their 1.9s, but I've used the 3.2s on HPI Savage with lots of power, huge air and high speeds, they were bulletproof and can be painted. "thumbsup""thumbsup""thumbsup"
