1.9 Pitbull rocker
I am, but I don't comp my mrc... they perform really good, but they are not comp tires.
On the MRC, just Losi Rock Claws.
The Pit Bulls have an advantage over the Claws because they are much taller... and IMHO, a better rubber compound but they do not have the open lugs that most comp tires have.
If you want to comp your MRC, you can not run the Pit Bulls because they exceed the max 4.25" OD tire size. If you really want to run them and comp, I guess you could do a cut and shut job on them.
IMO, the Pit Bull tires are awesome!
K I'm going to just butcher my flatirons and not worry about it then. Thanks for the info.
I did run a set of RTR Flat Irons on my MRC and replaced them with the Pit Bulls.
The Pit Bulls blow the Flat Irons away, no contest.
take a look at my build there is some pictures there, i cut the small lugs off in each row. the more you crawl with them the better they get.
