motoworx
Many requests for these so here they are!
2.2 XD17 For use with 17mm Hex Hubs
Description
New April of 2018 the 2.2 Extreme Duty 17mm Hex wheel.
Whats New:
This 2.2 wheel is designed to accept Motoworx Racing 17mm detachable hex hub
17mm HD 325 HEX HUB |
Backspacing is adjustable with the 17mm hex extenders in .200″ and .400″ increments
17mm HD HEX HUB EXTENDER |
2mm hardware is used on the beadlock rings and 2.5mm screws are included for the hex hub mounts.
The outer ring screw hole pattern on the 2.2 XD 17 Hole SLW wheel has a 16 hole or 8 hole mounting option. This allows for the use of an 8 hole outer ring in comp situations for quick tire changes or a 16 hole outer ring for scale effect.
Excess material has been machined out on side walls on the inboard wheel walls for weight savings without structural compromise
Description
Whats New:
