2.2 wheels to fit proline bead
D.Giroux
canada
What wheels are designed to fit shitty bead from proline tire
I bought some tsl sx XL, and when i want to put tire on my axial 8 hole beadlock wheels, its very difficult tou keep tire hold on the rim ?
any wheels or any advice to install these tires on regular wheels ?
Not sure the difference between the 2.2 and 1.9 TSL SX but that is what I run on 1.9 Axial beadlocks and they were not a problem to mount at all.
Most wheels should be no problem except RC4WD but there are solutions out there, they sell different inner rings for their wheels to run the Proline tires and you can get some from VP that work as well. Obviously this doesn't help with the Axial wheels but it's something to look into.
RC4WD Rings
VP Rings
Trouble installing them, or trouble keeping them seated once you're up and running?
Sometimes tires can be a pain to mount. Just takes practice and patience.
Most of the issues mounting Pro-line tires comes with the rc3wd wheels, they just don't play well together for the most part. Every other 2.2 wheel usually mount right up without issues. Can you post a pic of the problem that you are having?
