2.2's Are Perfect But What About 3.8's On Gen8?
10thMtnVet
Waverly
I'm fairly new to the RC Crawling world. Currently I'm running 2.2 Boggers on my Gen8 and it runs perfectly. No bashing, just chill trail work. However, I'm curious as to how I would get 3.8 tires on it and have it maintain function.
Care to shed some light?
um what size od do you plan to run some 3.8s are smaller than 2.2s some are over 8" tall
also your gona need to make it wider ether massive wheel spacers and i dought the axles will hold up may e if you aluminum them all out you could also use wider axles like ar60s and then your go a need to lift it and gear it down if using to much bigger tires
or you could just put the body on a clod buster
