monkeyracer
I've been wanting to build this truck for over 2 years now, but it's been hard finding 2 of these bodies in good shape to chop up and glue back together.
Well, now that walmart has these in stock, and I had a little cash burning a hole in my pocket, I bit the bullet and bought 2 of the bigger Silverado bodies. I scoured the local wally worlds, and found only 1 that had any Chevys, so I grabbed both.
The New Bright body is a Regular Cab, short bed, which was only offered by Chevy in the work truck trim with a 119" WB, and is why these things look so funky.
A coworker of mine has been looking at buying a pretty hard to find combo; Extended Cab, Short Bed. This is the extended cab with a 133.9" WB and the 5.75' bed (from the Crew Cab). Chevy offered this from '08 - '10 and only through special order. I wanted to build the truck he wants to buy.
Here's the only pic I could find from a very short google image search of this configuration:
And a photochop of a better res picture:
So, to start off, I took both bodies, marked the cuts, and mocked it up:
So, to compare the 1:10(ish) body with the 1:1 vehicle:
It looks like I've stretched it just a little short, but this was on purpose. The body is pretty close to 1:10 scale, so the wheelbase would have been 13.39" to be exact, but I think that is just way too big for 1.9's, so I only stretched it to 13" (which is still on the long side for 1.9's).
As far as what is going under the body, I am killing my Savvy Avvy build, and using the SCX chassis, IFS set-up from the RS4, flipped solid rear axle and stock trans from the AX10/SCX10 with the WB stretched to 13". Haven't nailed down electronics plans yet though.
Obviously, I have plenty of body work to do, with the hardest part being the roof. Although I may fudge it and make a small roof rack to hide the seam, I will probably use ABS cement, and a little bit of heat gun manipulation. This isn't my first Crew/Ext Cab extension, but these aren't easy either.
I haven't decided on color, but for this one, I am thinking about getting some Chevy "Stealth Grey Metallic" or "Carbon Flash Metallic" from paintscratch.com for an authentic color.
So, then what do I do with the leftover parts from the donor body?
That's a perfectly good front clip and bed... So, how about a more extreme C3 crawler? Tube doors & bed, pinched nose, etc. Stay tuned for that build as well.
As always, questions, comments and suggestions are welcome.
