G
Ghost Rider
Guest
I am building a 1/24 scale crawler. 5" wheelbase, it has super slick axles with SS steering servo mounted on the axle. 90 degrees articulation. stock super slick 1 links front and rear. cut up wally crawler tires. custom 2" travel shocks with ~3/8" uptravel. plate style chassis out of 1mm aluminum. total weight will be not much more than a regular super slick. Trans is my favorite part, it is a wally crawler motor and trans doubler with the super slick trans. it is VERY slow even with 9v juice. I may have to go to bigger tires it is so slow. Im sure as hell not making another doubler. the only problem is how the doubler is clocked. makes the COG kinda high so there is a lot of body roll.
I have 1/24 scout II and full size bronco bodies for it. pretty scale looking if a little tall.
so my questions:
I saw on here that xmods use propo electronics. would the electrics hold up to 9v power? I think the motor will, I ran a 9v on a wally crawler with no problems and this will have waaay more gear reduction. how would the run time be? I want at least 20 minutes out of a battery.
dont laugh that this setup sounds kinda ghetto, my goal was to build as small a crawler as I could for cheap, I have about $20 in it thus far.
I may go to hobby grade electronics If it is not too expensive. I am new to RC stuff so I dont know what all I will need. all electrics and battery need to fit in a 1.5"x.5x2" space. can anyone get me on the right track?
thanks,
Jeremy
so my questions:
thanks,
Jeremy
