Adapters for axial tranny to WK axle.
rottenbelly
Just jump it!
Cedar City, Utah
Anyone know what i need to hook up a axial tranny to WK axles? I have the shafts from both but am having problems matching them up. The axles are 5 mm and the WK are 6mm.
i am guessing you can just use the yokes from the wk axles and the yokes from the axial tranny and put them on stamped drives shafts. Your best bet is yo sell you WK axles for 55 and through down another 20 and get some axial axles"thumbsup"
Or you can run some CDW 6mm outputs on the Axial. Otherwise you'll run into clearance issues if your running a larger spur.
I am running the regular cdw Outputs that fit the stock Axial driveshafts. But i still want to run my Wk axles till i can get some AX 10s. My WK axles have the strc lockouts on baack and all aluminum goodys with mips up front and are pretty tough so i kinda like them.
Or you could hack up both the driveshafts and mate them together. Mine are butchered WK shaft to Axial shaft to WK shaft and it holds together fine "thumbsup" Just make sure you have all the right measurements for compression and droop. I didnt the first time and on compression it blew the dshaft apart. Since I measured properly I have yet to run into a dshaft issue. 8)
I am running Pede shafts with the same combo you have. WK axles and Axial trans. I just drilled out the Yoke a little to fit the axles and I havent had any problems so far. I tend to twist the shafts before they break at the yokes.
