Whats_a_dickfer
Been running this set of DJ Crawler 70mm 1.3's on my trx4m build. Cut the lugs on all four as you can see here compared to stock.
Definite improvement after cutting the lugs. Running them in the reverse direction also seems to work better. As far as inserts I'm using yellow injora silicone ones with the outer rings trimmed off.
I'm still fighting for more grip/bite when the wheels are pointed straight ahead. They seem to grab a lot better with the steering cranked. And sometimes the front end just wants to wash out. The terrain is mostly smooth-ish rocks with sharp corners and big ledges to try to pull over.
Maybe cut some sipes into the lugs, but oriented at 90 degrees to the direction of travel? Trim or re-shape the remaining lugs?
