I am having a hard time getting the control that I need with my current airbrush which is an Aztec double action.
http://www.testors.com/catalog_item.asp?itemNbr=2260
I cannot get a consistent paint flow, I'll set the airflow and pull back a little to get the paint to come through, but every time the paint flows differently, sometimes not at all. As a result of this I get globs of paint that hit the body and the air pushes it around creating little streams from the glob. When I can get a consistent stream, the paint splatters out of the tip. I am trying to do a multi color flame job and I don't have the control that I need with the really narrow flame tips, not to mention the flame tips that are wider than the stream. I'm using Faskolor paint and a 2 Gal compressor with a moisture trap at the compressor.
So my question(s) are, is the paint at fault? Is the moisture trap location at fault? Is the airbrush at fault? Or is it a combination of all three.
I believe that it is all three and I was thinking of ordering an Iwata (http://www.coastairbrush.com/proddetail.asp?prod=ECL2500) and maybe an inline mousture trap in addition to the one at the compressor.
So guys chime in. Let me know what you think and if you have any suggestions let me know. Thanks!
