allen key and nut size for micro?
SNCrawler
Cerritos
Does anyone know the allen key size and nut size for the micro, I want to buy tools because the ones included with the kit are horrible, especially the plastic socket tool
the hex heads are .05, I can't remember the wheel nuts size.
it's been discussed before, you should be able to search and find the answers. "thumbsup"
wheel nuts: 4.5mm socket, 2mm thread nut.
micro hardwear: .05 hex, 0-80 thread.
Not 100% sure but i think 1.5mm and 2.0mm hex also, i would have to look at home later though to be sure.
Wiha tool company makes some great tools for cheap. Check Amazon. FYI...if you get BDW Vertex wheels you will need a very thin wall nut driver. I have a fine phillips head screw driver and the 4.5mm nut driver for the crawler and some at in my toolbox at work. they work great and are good quality.
4.5mm=wheels and slipper nut
.050=ball joint studs
#2 hex for steering knuckle.
http://www.amazon.com/Wiha-Driver-P...3DFW/ref=sr_1_1?ie=UTF8&qid=1304265057&sr=8-1
