ntemple46
So I just took my TXT for its first run. I am still having issues with the electrics because the two hitec 5955 servos are robbing the esc of too much juice (second BEC on order soon). That being said, this was my first experience with brushless..... WOW:shock::shock:. Novak HV 6.5 on two 5000 packs. The truck was basically uncontrollable. I rolled it a bunch of times. It will wheelie in forward, reverse, even when running half throttle and giving it a burst it will pull up the front end and flip it on its back. I definitely need to lower the CG and soften the suspension a bit. I wasn't ale to do a full speed test run yet as the glitching electronics made me nervous to loose it at full speed. But I can see that this will be fun and quite fast once I get it all dialed in. I will do a rock test once I find something to climb on. Not expecting wonders in that area as it is basically stock and needs quite a few mods to make it worthy of crawling.
