I have SSD chubs and knucks and so far have stripped two axle housings on the splines. The first was the stock housing on the passenger side, the second was the drivers side on the Xtra Speed alloy axles. Not sure if drilling through the threads in the chub to pinch it together around the axle housing with a screw and nut would be work or not. Suggestions?
But has anyone else experienced the stripped splines? I have only taken it out three times, not too rough on it either. (I know I could go vanquish.... not on my budget at the moment) Also, the pic is from the first time it happened.
