jessedacri
Hey all -
So I chewed up my stock Axial one piece ring gear that came with the builder's kit on my last run, so I ordered up some SSD upgrades. Got the SSD HD steel locker and axle gear kit with the HD steel ring and pinion gears. I haven't built two piece lockers yet as this is my first Axial, but it seems to me that these three tiny screws can easily snap, undermining the point of the hardened steel upgrade. I understand that AR44s have come stock with the 2piece setup in the past so it isn't exclusive to SSD, but what's everyone's thoughts on this? Non-issue?
And more immediately pressing, what size are the screws that SSD provides? My 2mm hex is too big (both Dynamite and Husky) and my 1.5mm hex turns the screw but ultimately rotates in the screw when any torque is needed (to tighten them at the bottom. I'm afraid they'll strip if I try any more. Smallest imperial size I have is 5/64 and that's too big as well. What do I need to pick up to properly screw these in, and are there stronger or more standard screws I can get? Currently I can tear down my whole truck with just 2-3 sizes of hex, would like to keep this standard!
My other SSD upgrades have been spot on so I went with them here as well, but I'm now thinking I should have probably grabbed those keyed Boom Racing lockers that offload the stress from the screws as I'm running 4S with a Puller Pro 2700kv.
Thanks in advance for the input!
