WRXronald
PIcked up and Arktos 6x6 -- grossly under-powered unless all you want to do is crawl, just my opinion.
Squeezed the Mini16 in, went with a 12t pinion (stock is 11t, 0.4 modules) --- the Mini16 is 2.3mm shaft and the 12t pinion is 1.98mm bore (one I had on hand) so I got a 2.3mm drill bit, bored out the pinion gear, and the Mini16 comes with a flat spot so I was able to get a drop of quality CA in there and its holding beautifully so far!!! Other than that fit is pretty standard, had to add my own Rx and splice and solder in standard servo plugs and all the lights, etc, took a good bit at the table.
Couple pics and a quick test run... I really am not into the stock wheels and tires --- didn't even run them once. Up for grabs if anyone would like them lol.
Keeping it stock until stuff breaks -- was kinda disappointed to find bushings throughout??? But metal gears throughout too -- an oxy moron approach lol.
Anyways -- this run is on 2s, can use 3s and found no heat in the motor at all yet -- that's good cuz there not really any room for a fan, etc unless cut a channel thru bottom of cab floor and put a fan tunnel or something.
Goal is for FAST 2nd gear for mud/snow thrash and crawl torque -- so far I am super impressed with Fusion performance -- it IS all that who knew lol. Jk I know everyone loves it that uses it. I plan to submerge it soon, in mud too. Its already been a good bit wet once but the lipo went low as I forogt to charge it and the stock one can't hang. This vid is on 2s 1000mah graphene lipo cells.
Putting 1.0 Fling Kings on but honestly they are as small as the stock tires --- and now that i've seen the bigger FCX18 tires on here and they work ok enough -- why not go another round up and run some 74x27's lol ---- 1.0's --- should look Mega Truck outrageous!!!
Will at least post pics of the Fling Kings if I don't run them at all -- I may just turn around and sell them if I can get the 74mm's working well enough.
Other than that -- she runs REALLY smooth at high speed - I think it can handle 3s power - no sure how long the bushing situation holds out though.
With FCX18 K10 wheels and tires!!! -- looks cool if you ask me!
Added metal driveshafts as well -- simple enough to complete the "all metal" drivetrain components topic.... we'll see how well plastic housings hold up -- but so far they seem decent quality just needs bearings.
