Ascender Link Risers
Nick1975
UK
This may have been covered before but i thought id share it anyway, On the never ending road to reducing the torque twist on the ascender the easiest mod is to raise the rear top links, Doesn't cure it but it helps, I looked at several ways of doing it but struck upon a simple mod to do it in the end,
The only thing is it only works if you don't use the stock battery mount position (i run the battery across the chassis like the scx mod)
Basically all you need to do is swap the plastic side blocks around and mount the links on what would be the battery mount pivot points, Very simple, Strong and effective mod
