maxbonv
So I guess I'm not totally understanding this. You need the 2 speed transmission correct? And with this mod it allows you to have low gear for both axles. Then high gear for front only? No more high gear for front AND rear axles? I've got a two speed transmission I'm putting in my truck for more wheel speed and fun. If this allows basically 3 settings as in, low for both axles, high for both axles, and high I the front only I'd be interested. Thanks
Ben
This modify does not permit Low speed for both axles.
Normally you drive in High speed, when you select overdrive, rear axle turn in low speed.
