My goal isn't a comp crawler, or a crawler that adheres to the rules of what a current crawler should be using - I'm not going to be light, and I know my motor choice wont be best. I'm out for basic crawling capability and fun. Maybe I'll optimize a bit more later. I've learned a lot from this forum, so I know I'm heading in a direction most wont.
I doubt I can shave axles like many here do. If I try it, i'm sure I'd destroy something.
Most of the parts I'm using on this project are from clearance, or heavily discounted ebay sales.
This started as an open diff rock racer, and halfway through i changed my mind.
I originally picked up ax10 axles to make a "buggy".
And I really liked how it turned out. Sure my c-o-g was higher than a comparable RC, but this was mine - I sourced parts, figured out my mounting choices, made links - this was exhilarating. You guys remember your first build? Awesome right?!
So I had to make another.
PC295901
OK so that last one has undergone transformations with the shock and battery mounting constantly. I think I just need bigger wheels. Stepping over stuff is fun.
Anyhoo, sometimes when I see a deal - something on clearance, I go for it. After breaking the axle housings a couple of times (my first buggy) I realized the AX10 housings are ok for load, but bad for impact at speed. So I've been using aluminum housings (rc4wd housings on the first, golden horizon on the second).
A couple years ago I saw a deal on some ugly looking green anodized golden horizon axles, STRC 4 link plates, blue knuckles, lime green chubs and a Fast Lane RC 55mm SPV chassis.
A couple months ago I started getting interested in getting all my RCs working again, and saw these parts in a box. I decided well... why not.
So I layed out some available parts
P6235798
P6235796
Now you can see why i'm calling it "Gaudy"...
The different green shades clash, blue kills any uniformity.
A few weeks ago I thought to myself halfway to making this roller - I htink I should make a crawler instead. I have enough go-fast fun-vees. Ever change your mind way into a project? yup!
Changes: Diffs, motor, spur. I went from 14:36 open diffs, to 13:43 locked.
Holy crap it's annoying to get at AX10 diffs when you've got servos mounted and all.
The velineon went and in came a generic $20 1650kv brushless motor. I know - i know - it's better to to brushed. But I already had a $30 brushless ESC (hobbypower - a hobbywing clone - i.e. same esc as hpi flux v2) so this was cheap. Plus I kinda like the idea of not worrying about brushes. I saw spare few reviews on these motors, so I'm taking a chance. I've seen other people spend more on lotto, so this is probably a better deal.
Shafts are junfac I think it was from rc-recycler? $20 for a pair. Looked like it was never used. i've destroyed a few plastic ones, so my other ax10s are using MIPs - but I'm trying to be cheap here, and read decent review on the junfac.
On my faster builds, I use 32 pitch NTC3 spurs, so I'm jumping from a 56 tooth spur to 87. Pinion is down from 18 teeth to 14.
Up next links, shocks, electronics.
This is also going to be my first 4 wheel steer vehicle. I know digs are more capable from watching videos, but I'm not looking at competing in anything.
Couple more pics, since I'm REALLY BORED in-between waiting for different packages to come in... Waiting for some Solar servos to replace the MG996rs I've been playing with.
P7075927
P7115931
Found some old mini-t shock spring replacements from when I was a Mini-guy. those fit nicely on the Maxx shocks for a more narrow profile.
Something about the chassis I don't really like though. It needs some curves...
