rcpaintworks
Got some components for my AX10 from Hobbyking:
HXT12K Digital MG Servo US$7.85
Torque Rate: 10KG
Speed: .16sec/60deg
Input: 5~7v
Type: Digital
Gearing: Metal
Weight: 55g
Size: 40.7 x 19.7 x 42.9mm
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=2
Very good servo, strong, good centering, metal gears, Futaba horn, unbeatable price.
Turnigy 1300mAh 3S 20C Lipo Pack
Pack Size: 72 x 36 x 24mm
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=9272
I have the 3Racing (#AX10-18/WO) Battery & Servo Plate for AX10 Scorpion to place the LiPo on the axle. Fits perfect.
Turnigy 2217 20turn 860kv 22A Outrunner US$13.28
Kv: 860rpm/v
Operating Current: 6A ~ 17A
Peak Current: 17A
Weight: 71g
Dimensions: 27.6 x 36mm
Shaft Size: 3.175mm
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=5691
With it's 14 poles it runs smooth as silk on 3s. Tons of torque. Sensational little motor.
HobbyKing Brushless Car ESC 30A w/ Reverse US$14.99
2-3S LiPo with CutOff
Cont. Current: 30A
BEC output: 2A /5V (Linear)
Programmable with DragBrake etc.
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=11742
Motor already has 3.5mm bullet connector, you need 3 for the esc and a power connector of your choice. The Motor fits the Outrunner motor plate.
Torque Rate: 10KG
Speed: .16sec/60deg
Input: 5~7v
Type: Digital
Gearing: Metal
Weight: 55g
Kv: 860rpm/v
Peak Current: 17A
Weight: 71g
Shaft Size: 3.175mm
Cont. Current: 30A
