Shayne82609
Here's my steering system. A bit different, thought I would give it a try. The servo mount is a piece of 1" aluminum angle I picked up at my local Menard's. Trimmed it and shaved it to fit 2 standard servos. Its screwed down to the stock mount locations, as well as one bolt and spacer to the outer "battery mount" locations.
The left servo is a Hobby City HD-9150MG. Its has plenty of torque, its super quiet, moves like a Swiss watch, and will suck enough amps to trigger a computerized receiver's low volt throttle cut (theres a story to that one, trust me). Its a little taller that a standard servo, but it works great in this setup. After 1/2 hour of crawling, its just a little above ambient temp.
http://www.hobbycity.com/hobbycity/store/uh_viewitem.asp?idproduct=6334
The right servo is a housing and output shaft of a MG995 that's been filled with BB's and hot glue. Its just there to hold the idler arm. If I ever felt the need to crush something with my steering I could replace it with another 9150MG.
Both of the servo arms are standard aluminum off shelf parts. All of my rod ends are Traxxas Revo parts with 8/32" all tread holding them together.
Steering knuckles are CKRC high steer knuckles. These are some quality peices, highly recommended, even if your using an otherwise stock setup.
http://www.ckrccrawlers.com/shop/index.php?main_page=product_info&products_id=1467
Heres an Ackerman shot. Seems to work quite well. "thumbsup"
The whole thing moves effortlessly. No bind points anywhere (unless you consider the tires hitting the springs a bind point), and has very little flex. The little bit of flex that is there is very tolerable, and gives it a little bit of squish room for impacts.
Give me some feedback folks.
Thanks,
Thanks,
