Axial AE-2 ESC Question
HDMM
Bunnell, Fl.
OK, just want to confirm this, I have a couple of the Axial AE-2 ESC's and I have the Castlelink and I have been messing with the programming. Can you run a brushless motor with this ESC ? ON the motor settings, they only show 2 choices, brushed reversable and high power motor. I'm guessing the high power one would be a brushless motor? Just want to confirm....thanks.
What would the "high power" mtor option be for then? I tied to get the info from axial...got nothing....
I atcually took the esc out of my wraith and stuck it in my old RC10 with a Trinity Cobalt 27t motor. You set the no reverse in that particular settings section. It works great as a car ESC because you can program it accordingly. Just want to know if if I had the ption t go brushless at some point.
I'm upgrading the Wraith t the Tekin ESC / brushed motor.
If you want to go brushless you'll need a brushless ESC. The AE-2 is actually quite good for brushed and I like mine a lot. When you do go brushless it's best to buy an ESC that is sensored so you can run a motor with a sensor. Many of the less expensive controllers omit the sensor part and you have no way to connect it.
Basically, the sensor allows the ESC to have better control of the motor so it knows where the rotor is in it's rotation. What does this mean in English? Sensored ESC/motor combo is better for crawling because you have low speed control.
Popular choices for that type of ESC are Tekin RS or RX8, Castle Mamba Max Pro (MMP for short) and some of us have recently started playing around wiht the controllers from BrushlessHobbies.com.
I atcually took the esc out of my wraith and stuck it in my old RC10 with a Trinity Cobalt 27t motor. You set the no reverse in that particular settings section. It works great as a car ESC because you can program it accordingly. Just want to know if if I had the option to go brushless at some point.
Setting "no reverse" in the ESC is a bit different from wiring it "high powered". High powered can get a bit more performance, but makes it so you CAN'T use reverse, regardless of how you program the ESC.8)
So when you do high powered wiring mode on the AE-2 do you wire it like the regular sidewinder? http://www.castlecreations.com/support/documents/drivers_ed_guide.pdf
In that you stick all 3 wires on the + side of the motor and negative of motor goes direct to negative of battery. For AE-2 I'm wondering how it would be wired since it's brushed only.
the regular sidewinder has three wires out to the motor, the ae-2 doesn't, I see that now. Its wired for burshed motors, only.
