Axial AX-10 Picture archive - No talking
my latest
My ax10
Added:
Axial aluminum link kit. (orange)
Axial 55t motor w/ 20t pinion
Traxxas Rod ends
Axial vert mounts
proline bronco body
On the list.
Hitec 645mg (Ordered)
Traxxas Rodends (3 link)
Axial 3 link connector ends
Axial drive shaft ring
Panther Cougar 2.2 w/ soft foams
Axial frame extentions
Heres the pics as of right now. enjoy!!
Out of the box RTR
NOW:
kinda going for the scale look......
My used to be rtr.
Purchased as a rtr. Now is a comp rig at least in my oppinion;-)
RTR
Green color pack added
Green front bent links also added
Red upper links added to break it up some
Custom lexan upper link plates for electronics
STRC tranny mount plate with links mounted internally
Losi comp shocks
Custom 4-link plates front and rear
battery mount on either side of steering servo
CKRC wiggle steering servo
Castle Creations Sidewinder ESC with CC BEC
Novak 55 brushed motor
Panther tires front and rear weighted
TQ3 link 2.4ghz system
Losi comp body for now
Dig in near future.
Oh and my bro. in laws redcat.
Heres mine, FF-4 all the way!! It has evolved a little-stock artr to slingshot to ff-4 to the present Fastback!!
My AX-10 Vanquish
Hello
My AX-10 Vanquish
Chassis Axial Pro VP Incision
VP Hurtz Shifter 3 Position Dig for Axial AX-10
Vanquish Axial Rear 4 Link plate
VP Axial Front Battery/Servo 4 Link Plate
VP Shock Mount Razors
VP Axial Rear Axle Lockouts
VP Axial High Steering Knuckles Zero Acker
VP Axial AX-10 Alum Trans Housing
Radio: DX3R
ESC: Mamba Max Pro
Engine: 21, T Novak Brushless
BEC: Castle 10AMP
Lipo: 3s 1500mAh 20c
Servo: Hitec HS-7950TH
Transmission: MIP
Axles: Golden Horizon
Tyres: HB Ex-Rover
Rims: VP Procomp DH 2.2
Bumpers: Losi
Measure Wheelbase: 320mm
Overall width: 240mm
Clearance of difference: Blocked
Center Chassis clearance: 80mm
Overall height: 180mm
Weight: 2900Kg
Body: Beetle
Regards"thumbsup"
Freitas
F-150 axial
cut boggers
motor 55t/19t
traxxas 2075 servo
Jeep axial frame
36/14 front gear set
43/13 rear gear set
motor 35t/14t, soon to be 55t/21t
Novak orange esc
traxxas 2076 servo
2.2 roklox
I'm in the process of slowly rebuilding my AX-10.
I'm going with a Van body and thinking about getting the SCX10 frame set.
The old F-150 body I had. I wish I would've taken better care of it and went down to 1.9s instead of trying to figure out a way to fit 40 series tires haha
another ax10 with proline tube body
Axial ax-10
Proline tuber body
Novak 55T motor (swapped sides)
Rooster Crawler ESC
Panthers on proline wheels, memory foams
Hitec rs 5645mg servo
Hitec agressor tx
3300 and 4400 NiCd batteries
mods...
extended upper links(50>70), redrilled chasis
mip racing steel HD driveshafts
inboarded lower links
slipper clutch
booty fabbed output shaft
oh and rock lights !!
day one, per the instructions
today, per some breakages, post reading, and creative modding
my custom AX10 crawler. (custom, or bolt on? I dunno, I like it)
started as a stock ARTR kit when I got it,
-Integy Matrix pro 55t motor
-Integy HD Driveshafts
-Robinson Racing solid steel gear/outputs
-XL5 waterproof ESC (mounted on front links)
-Team Associated TX/RX
-towerpro MG996R steering servo with alum. horn
-turnigy 1600mah 2 cell lipo (mounted on rear links)
-weighted wheels/cut foams (proline hammers)
-Integy steel tube chassis, skinned with soda cans
-RC4WD 109mm aluminum bodied shocks, REALY soft springs. (I did not like the ride height I got with the ARTR shocks)
next on the list is aluminum wheels, and a new set of tires, still unsure on what though.
might be forgetting stuff, i'd like to know what you guys think of it.
thanks for looking, cheers
FF-4 chassis (thanx DickyT)
VP dig
MIP drive shafts
Hitec 7950 servo
LD bta
G made shocks
Novak 55
Gold Losi springs
Rooster crawler esc
Motoworx 7 spoke AL wheels
White rovers
Pro line 2 stage foam
Axial high knuckles
Unkown al C's
CC BEC 7v
Gunnar body mounts
Hitec 645 dig servo
Racers edge pro servo horn
3 Racing cvd
homemade links
2s batteries
Proline Crowd Pleazer body
Started life as an AX-10 Kit:
CHASSIS: VP Incision
AXLES: Front- Axial heavy duty R&P, Axial CVDs, HR heavy duty spool, RCP Cs
Rear-VP lockouts, VP Razor shock mounts, Axial Straights, TCS Boomerang uppers mount, Axial heavy duty R&P
STEERING: Hitec HS 7950TH (w/ Hot Bodies aluminum arm), CKRC BTA w/CKRC high steer knuckles
SUSPENSION: 3 link front / 4 link rear, Axial Comp Shocks, Axial 70mm uppers, East End Machining
lowers (bent rears)
DRIVETRAIN: VP transmission housing w/ HR aluminum gears, spur and spur mount, VP Hurtz Dig w/
Hitec servo (cheapie for now!), MIP cvd drive shafts
WHEELS & TIRES: Pro Line Chisels on Mayhem Engineering Competition Double Phattys
ELECTRONICS: Novak Goat w/ 55 brushed motor, Spektrum DX3R w/ sr3100 receiver, CKRC 1300mah
7.4v lipo
BODY: Axial XC-1 Black w/ Tamiya dull coat on outside
Axial AX10
HR Chassis
HR skid plate
HR bent lower links
HR upper links
HR Stearing links
HR shocks
Losi Rock Claws cut foams
CC SideWinder esc
JR Racing Z590M servo
parts yet to put on, new body, Sedonas, new servo, internals.
heres some action shots from today
My turn:
Bought used ax10 with alloy links and 3racing chassis.
Hot Racing dig
Novak 55t
3racing front driveshaft
I've since added 4s lipo, HH BR-XL, MIP driveshaft rear, and rc4wd aluminum wheels with panther leopard tires.
ax10 warthog
here is my comp ready ax10 with warthog chassis. what you guys think???
she used to look like this:
now she looks like this:
questions welcomed...thanks for looking!
