Axial AX-10 Picture archive - No talking
DMG on Poulson Axles
Some used stuff I picked up. The DMG Alluminiti from Greece, and some Poulson Axles from Zorlac, YA the DMG guy. But really the only AX10 thing left is the trans.
Stock trans Metal Gears
VP Hurtz Dig
Tekin FXR
Novak 45T
CC BEC
3s Lipos
MIP Shafts
Poulsons
JR8711 steering
Losi Shocks
RC4WD Wheels
PL Chisels
Are they ever complete?
novak rooster,
novak 45 turn,
self built tube frame,
spektrum dx3e radio, reciever, and servo
robinson racing output gear,
pro line flat irons (sedonas are on the way)
home built battery tray(have since cut up and resoldered battery packs into saddle packs but don't have a new pic)
high clearance knuckles,
integy piggybacks,(they need to be replaced with something shorter)
It still needs the tranny pan to be switched to delrin and a lot of other stuff but it is loads of fun as it is and a far cry from the rtr it was a few weeks ago.
My AX10 Kit truck
Novak rooster crawler esc
Novak 55t motor
Venom power li-po
JR 8711 front servo
traxxas 2075 rear servo (soon to be changed)
Spectrum DX3E radio
Tamiya light unit with custom light buckets and spot lights.
GoPro Hero camera.
Herbie Rally Edition
STRC Aluminum Knuckles, C's, and rear lock outs
STRC 4 link Rear
OD Front
UD Rear
Robinson Steel Internal Gears
MIP C Splines
Sidewinder on 3S
CC BEC
Hitec 7955TG @ 6V
VP Incision Pro Chassis
DNA Thrashers 2.2
HB White Dot Rovers
Proline Dual Stage Memory Foams
R2J Delrin lowers
Losi 4" Comp Shocks on Gold Springs 45wt
Spektrum 2.4Ghz SR3100
Proline Bug Body Herbie Rally Scheme
Heres mine, picked it up used for $250, put another $200 or so in it so far (including radio)
Specs
--Spectrum DX3E 2.4ghz.radio
--Overdriven front steel bevel gearset 14t/36t
--Stock ratio rear steel bevel gearset 13t/38t
--Vent holes drilled in rims
--Battery relocated to back axle
--Around 1.5lbs of screw in wheel weights on front
--Around 1 lb of screw in wheel weights on back
--Futaba heavy duty metal geared servo
--Fast lane machine Heavy duty rear spool with set screws
--STRC heavy duty Steel rear lock out axles
--Full droop setup on shocks so link bars are parallel to the ground
--All aluminum Integy link bars, steering, and driveshafts
--Racers Edge Aluminum Pro Adjustable Servo Horn
--Integy brand shocks
--Transmission upgraded to all steel geared and pinioned Integy kit
--3racing Aluminum transmission housing
--3racing Aluminum steering knuckles
--Novak 55t motor
--Rooster crawler ESC
--Inboarded lower links
--Outboarded shocks
--Aluminum lock on wheel hexes
--Aluminum axle end upper link mounts
--Aluminum lateral braces
--Aluminum servo mounts
--Venom creeper wheels
--Front tires are Pro-line chisels 2.3" wide by 5.4" tall
--Rear tires are Hpi racing Rock Grabbers 2.3" wide by 5.4" tall
David's Axial Ax10 :D
Hi im David from the Philippines id like to share with you my Axial Comp Spec Rig?lol..Im VERY NEW to Crawling so please bear wih me :mrgreen: Heres my newbie set-up :lmao:
Heres my set up:
Ax10 Kit
Carbon Fiber Chassis
Lots of STRC Upgrades
Tekin 55t Motor
Tekin Fxr Esc
2s 1350mah lipo
Tamiya Servo (waiting for my hi-tec)
Losi Claws
Beadlocks
DNA Dig (waiting for its servo din)
2.4ghz Radio
Aluminum Shocks
Please comment and let me know what else do i need. :D
Thanks!!:mrgreen: :mrgreen:
All dressed up and then in a beater body.... Stock except for four-way steering. When it stops raining I will get some more climbing pics.
Got mine used for $150 without an ESC, popped in a Novak Rooster!
Then got a TCS edge Chassis, picked some Losi Claws on RCC for cheap"thumbsup". Also have some 4 link front and rear and a newly flipped tranny!
more pics of my ax10 in action in bay st. louis.ms.
Welp, My AX10 has changed once again. It only had this body for a month or two
And then I couldn't help myself (after a failing attempt at building an exo truggy) from buying the Pro-Line Tuber
Since these pics were taken a few days ago, I made a 'hood' for the buggy, to make it more pleasing to look at!
Just realized Ive never added to this archive.
Happy to say this rig took home a first place finish at our clubs last point series and it was the highest placing Axial at the battlegrounds 2010.
Too many things to list for upgrades and mods so pm for any questions or closeups of anything. I'm not going to clutter this thread with a ton of pictures.
